I'm the maintenance electrician at a hospital and we have a big problem with the outside parking lot lights. every time we run the generator test with the hospital load, we burn out from 20 to 30 HiD 400w Metal Halide bulbs. And sometimes when the power utility company has problems with their transformers, the samething happens. is there something i can do to prevent this from keep happening. we do have a 6amp fuse on the bottom of the pole, do you think it will be better if we had smaller amperage on the circuits.?
