here is something that has puzzled for me for some time. air conditioner unit overcurrent protection.
when i wired houses it was oh so common to see a name plate rating of a unit and then we would put a cb on it that was higher. why and was it correct.
i am now about to place a disco on my unit and the name plate states 40amps, but as it sits now i have it fed with a 6-3 w/ground copper and the breaker is a 60amp.
believe it or not, i am not sure if what i (we) did was right, just dumb ignorance on my part, doing what we were taught without knowing the how or why.
is a 60amp breaker good, bad or ugly and/or should i just place a 40amp in there and it will work fine. i am sort of assuming the name plate is taking into consideration the motor start up.
advice or a place to look would be great here.
rw
rw
