Andy Taylor
New member
I am looking to use a connector on a Z-purged panel in a Class 1 Div 2 area.
The signals are all 24 Vdc or lower (RTD's, NAMUR proximity sensors, and thermostat contacts). NEC code 501.105 (B) 6 - appears to apply to this situation allowing me to use a non hazardous rated connector. Although item 3 of this section states : The power supply cord does not exceed 3 ft. Would these low level signals be considered the power supply cord ? - hence be limited to 3 ft ? (note I am using Class 1 Div 1 multiconductor cable to a field junction box which has the sensors wire to terminals) the cable will be hardwired into the junction box about 30' away.
