calisparky6
im doing a hot tub/ above ground 5k gallon pool install. my question is this...
i've seen spa GFCI load centers that have the required 2 pole 50a GFCI for hot tub AND also space for two additional breakers. isn't this essentially a sub panel? what i want to do is run #6THHN in pvc from main service with a 2pole 60a to a GFCI spa load center with GFCI 2 pole 50a (hot tub) and 1 pole 20a (pool pump). Are these load centers essentially treated as sub panels by the code? and what are the requirements for disconnect in this circumstance?
