Dryer
Not quite certain what you mean.
In the USA, a 4 wire dryer connection would normaly be HOT, HOT, NEUTRAL, GROUND. For use on standard 3 wire single phase 120/240 volt service.
A dryer outlet should be installed by a licensed electrician, but anyone can plug the dryer into a suitable existing outlet.
In Europe, most small or domestic dryers are for use on single phase 2 wire service at 220/240 volt. A 3 wire cord would be used with phase or live (normally brown), neutral (normally blue) and earth, green/yellow.
These normally require simply plugging in to a normal domestic outlet, not hardwiring by an electrician.
Larger dryers as used industrialy are often gas heated, and use only single phase electricity. These normaly plug into a standard outlet, though the gas connection and flue/vent would probably need a qaulified gas fitter.
Large electricly heated dryers do exist, normally for 3 phase service.
Some have a 4 wire connection, 3 phases and earth.
Others have a 5 wire connection, 3 phases, earth, and also neutral.
These normally require an electrician to install.
It would be possible to make a dryer that used 2 phases of a 3 phase supply, but I have never seen one.
Oh, your in Monrovia - never mind... Assuming Liberia... Hope you never adopt the National Electric Code, then you will also be at the mercy of every manufaturer that gets their latest money making idea crammed into the code.
By zip Coe, the Monrovia he is in appears to be Monrovia California :)
Perhaps the op is use to Gas dryers. In NYC, back when I work there lightyears ago, I had never seen an electric dryer or range. Almost unheard of because of the cost of electricity.
Has anyone seen a 2-pole 4 wire dryer before?
Usually, 'poles' refers to CCC's but not the EGC, so a 2-pole grounding plug would have three prongs.
If it has four wires, but only two 'poles', what is the "third" wire?
