Open Neutral
- Inside the Beltway
- Engineer
I'm look at the electrician's plans for a residence being fed by PGE with 480 delta.
There will be 3 grid-tie PV-fed inverters installed, then a long cable run, a 480delta:208/120 wye and the loads.
It's been a long time since I thought above 208; so I've been reviewing very dusty memories from ELT 443 w/Prof Klingshirn, as well as reading other sources.
