workin4living
Hello everyone, I have a question.......my father in law phoned me with a residential question. His neighbor has a 100Amp overhead service that from the bottom of the meter base on the side of the house drops out the SE wire that goes into the house and then a 10 ga wire drops out of the same meter base to feed a 30Amp disconnect for AC. Now they are wanting to replace the AC unit and they want the same setup only with updated disconnect. Is that legal to have two lines in the meter base and without a doubt on the same lugs? I thumbed thru code book but couldn't exactly find anything that was specific on the load side of the meter can. Wasn't sure if they would need to set and outside enclosure with a line from meter to disconnect that had 8 cir capacity and fed 100amp to house and then 30 to AC Unit. I appreciate your insight.
