Part of our PM is to do thermal temperatures at the tombstone of flourscent lighting, is there a formula or a spec sheet that would give me the temperature that the lamps at the tombstones should not exceed? I have simple 2 lamp 32 watt instant start ballast.
When I buy a thermometer, I look for one that reads in the middle of the range of them.Start taking readings. Once you find a bunch of them with roughly the same temp, then that's your normal operating range.
The bean counter who asked you to PM a tombstone should tell you
