wrestlingcoach
210.12(B) Specifies the areas in a Dwelling that are to be protected by an  listed Arc-Fault circuit interrupter, combination type. This does not list bathrooms, kitchens, garages or outside outlets. Im thinking these areas are not required to be arc-fault protected beacuse eventhough this article states "or similar rooms or areas." the code specifically refers to this areas elesewhere in the code (i.e. GFCI protection or spacing). I do not understand the reasoning behind this- I think all or none. It states in the NEC that the requirements of an arc-fault does not relinquish you from your GFCI requirements. So my question is why not arc-fault everything? I have read manufaturing specs that state the arc-fault will not interfere with the proper operation of a GFCI protection. Since these are two totaly different thing (Arc-fault and GFCI protection) why not Arc-fault the entire 120v system. I have read that homeowners could put a screw through a wire when hanging a mirror or picture. So whats to stop that from happening to the wire going to a microwave receptacle (thats not required to be GFCI or Arc-fault protected). Since these are not the same thing then what if this happens to a wire that is GFCI protected; since these breakers/outlets protect against two different things then a GFCI will not protect the circuit like an arc-fault or visa-versa. Please enlighten me I may be way of base but what do you guys think?
