PhaseShift
How does distance and signal wire size effect a mV signal?
With a 4-20mA signal the current is constant around the loop and the total resistance of the loop needs to be restricted to a certain value in order for the voltage supply to be able to push the maximum 20mA current throught the loop at any given time. Adding length or resistance to the loop will not effect the constant current signal as long as total resistance in loop is kept below maximum value.
What happens with a mV signal or 0-10V signal when resistance is changed? Does the signal drop voltage as it travels across the wires or resistance? For a 4-20mA signal you dont have to worry about drop acrross cable becasue mA signal stays constant and reciever is looking only at current signal? But what about a mV signal where reciever is looking a voltage signal, which may drop across signal cable?
