bcm
- Atlanta, Georgia
- Engineer
Having little DC power experience has me really scratching my head on the project I was just handed (due tomorrow, of course!).
I have a group of solar panels that generate 45KW DC. I am tasked with determining the wire size (and ground!?) between the panels and the inverter. I'm struggling to turn the 45KW into volts & amps since I have a bunch of different info about the panels:
*Performance Under Standard Test Conditions*
Maximum Power = 230 Wp (what's a Wp?)
Open Circuit Voltage = 36.9 V
Maximum Power Point voltage = 29.6 V
Short Circuit Current = 8.42A
Maximum Power Point Current = 7.76A
*Performance at 800 W/m^2, NOCT, AM 1.5*
Maximum Power = 164 Wp (what's a Wp?)
Open Circuit Voltage = 33.4 V
Maximum Power Point voltage = 26.6 V
Short Circuit Current = 6.96A
Maximum Power Point Current = 6.18A
Once I get DC watts, do I just use the tables in NEC Article 310 (310-16 to 21) to determine the wire size? Do I need a ground or is that just for AC?
Thanks so much guys! You are life-savers!
