Volta
- Columbus, Ohio
Grounded, or Grounding.
Yeah, that is a tough one in this trade.
No such thing as a ground wire, ground bar, ground lug, ground terminal, etc.
Hardworker, part of the problem is the terminology that you are using. In your opening post you stated you had a neutral lug that you were connecting to the ground bar. So do we have a neutral or a ground that you want under this lug.
Are you thinking since this is a neutral lug it won't work as an equipment grounding lug? I am confused.
