e2me2
- South Dakota
Do they make a main breaker for the homeline 20space 100 A that is only 60 -90 or can you just put in a 80 and not use the main breaker lugs but feed to the 80 to feed the panel like a main lug with lock down
If you are going to backfeed a breaker, just get an MLO panel.... no need for the 100a main.
Why not just protect the wiring with the 80 or 90a breaker at the feed end, and run it right into the 100a breaker in the panel?
So from what I understand Homeline does make a 80 amp main replacement
But if I cant find one in my area supply house will a 80A standered breaker work even though there is a main in the I will just feed the suppy to the 80 and leave the 100 a lugs empty or will this not be legal
I am finishing a job another electrician started but went out of business. He has a 100A 20 space homeline in the detatched garage and a 100a in the house using a double lug meter socket . But the garage is only feed with #2 alum.This is fine for the house but the garage is not a dwelling unit and needs #1 to feed the 100A so i was just going to drop the 100 main and use a 80 or 90 so all would be well .but was unsure if that was an option with homeline main at the top.Hope it is and a quick part number would be great if anyone has it. Therefore I can order online quickly.Thanks
