Jerseydaze
Can someone help me I have a customer who is putting a hot tub on a paver patio I know I need to lay coper mesh my question is how far out must the mesh be and must the mesh go under stairs?
That's what I do. 4-6" below subgrade and 18" to 24" from the inside wall of the tub. Then to the motor. I use a split bolt to tie the loop.2008 code if I understand you I can circle the hot tub with a bare #8
I didn't know you had to do this for a hot tub. I knew for a pool. So even if the hot tub is sitting on a wood deck off the ground?
That's not making sense to me. If you're on a deck you are elevated from the ground. Making contact with both the ground and the tub is, at that point, impossible rendering the bare ground loop useless. I thought that code was to keep everything at the same potential so you couldn't get shocked by having one foot in the tub and the other on the pavers, patio or grass. I think someone needs to offer some clarification.![]()
