Alwayslearningelec
- NJ
- Estimator
I see in the specs lots of times that it says solid for #10 or smaller and stranded for larger than #10. Why is that?
Also, have you ever tried to pull a #8 solid in a conduit. Well if you have try a #4 or #2 never mind 3/0 :grin::grin:I see in the specs lots of times that it says solid for #10 or smaller and stranded for larger than #10. Why is that?
310.3 '08
The question is really why do they spec stranded for #10 and smaller? I really am not sure. I know EC's like it because it is easier to pull but not sure why it is speced.
Because some EE specced it once, and they simply copy specs from one job to the next. So far, no one has called the EE to complain, so it keeps getting copied. You don't think they type those 4-volume spec manuals from scratch, do you?
That is irrelevant to the OP question. It does not even mention anything about conductors smaller than #8.
I never ever see specifications for things that do not even apply to the project on the prints.:roll:
Here is some interesting info. I hope it is accurate.![]()
Most of the time solid is what I see specified for small conductors, and that is what the OP is asking about.
(#10 awg is smaller the #8 awg)
Using solid on smaller wire sizes is specified by engineers who believe that stranded wire can be damaged in the pulling process causing the wire to stretch and the conductor diameter to shrink reducing it's amperage carrying capability. Myself, i like the installation process of solid wire up thru #12 .
