greetings,
I am replacing an MCC at a plant where several of the top breakers are higher than the 6'-7" of 404.8. (it's set on a 10" plinth because I think that someone forgot that 3" seals are about 10" high, back in the early 70's :roll
The operators have made their own 18" long hook stick out of a broom handle. I've spent a lot of time telling them that this is not to code. Then I refresh my memory on maximum height, and I find that Exception 3 allows hook switch operable isolating switches at greater heights.
Is this actually an acceptable use and application? Becasue it will be a LOT cheaper to get them a couple of fancy new hooks than providing a platform all the way around the MCC. I was unable to sturcture the new MCC to get all the handles below 6'-7".
If you don't think that a hook is legal, would you consider that an OSHA approved moveable step to be a legal working platform? It would also be considerably cheaper. I'm not opposed to the permenent platform, just trying to keep things simpler.
thanks for any opinions and info.
