A whole hearty AGREE!You do not want to pull this without the tugger.
I'd say you would not get it in by hand. Pull in in 3 hours or less, yes, but I'd still allot the whole day (setup breakdown time).It would take all day to pull by hand vs. 3hrs with the tugger, plus your guys won't curse you when your not around.
I am going to have to pull 440' of (3) 250mcm with a 3/0 aluminum through a 2 1/2" sch 40 pvc, (2) 90's. what do you guys think, how many men and how long to pull by hand.
Being a dumb engineer and all that, I have often wondered why these kind of things are not broken up into shorter chunks to make it easier to pull. It would seem to be a whole lot simpler to pull this in 2 chunks, maybe starting at each end, and connecting at a jbox in the middle somewhere.
It would seem to reduce the risk of something going really bad by a lot, as well as reducing the labor.
Depending on where this pull is, you can use the work truck to pull the rope.
We did a similar pull using the scissors lift. I mounted a pulley just above the panel, and then tied the rope on the back of the lift. It had no trouble pulling that 450 foot run of feeder cable thru that conduit!![]()
The advantage to using a Greenlee Tugger is that work force gauge. It tells you how hard the tugger is working and you know if you are pulling too hard. Using a truck or lift or whatever you really take the chance that you damage the conductors.
That being said, I have used a Lull to make a pull.
......... one to operate tugger, and one to pull rope off of tugger..........
One person can do both. I've never had two people at the tugger end.
I agree one person can do both.
I like to have two guys there for better communication and if something goes south it can be put to a stop quicker.
Or sometimes there is nowhere to mount the beast and two guys have to stand on it(not safe)
