kbsparky
- Delmarva, USA
I am installing some outdoor luminaries, which appear to be designed to be connected with a flexible cord.  They have a built-in clamp with a rubber grommet, and it appears that would work keeping a weather tight connection.
Since these fixtures will be exposed to the elements, including a great deal of sunlight, I want to use a cord that will hold up over the long term.
I was considering using something like VuTron or SJTW cable for this. I have seen installations using SJ cable , SO, or SOW that literally frayed apart after just a few years.
These fixtures are operating at 480 Volts, so any cable rated at 300 Volts might not be suitable.
What have you used in your applications and how has it held up over the long term?
