If i were to put a feed thru 200A panel to feed another 200A panel, would the second panel have to have the neutrals and grounds seperated because i would be running 4 conductors. Im a little confused because its not quite a sub panel ?
This is what I call a feed-through panel:
Two tubs, side-by-side, one panel with circuits 1-42, the other panel with circuits 2-84.
Would you believe "circuits 43-84"?. . . the other panel with circuits 2-84.
That's how it's done. But if the second panel is in another building, then you can use (3) wires prior to '08
