I agree about what you said, However the inspector has another openion that the (-) wire from a PV module is not considered as a CCC.
You cannot switch the grounded circuit of a DC system in the US, which also must be the negative in a solar PV system.
. You cannot switch the grounded circuit of a DC system in the US, which also must be the negative in a solar PV system.
You're right, I was reading too much into it.The NEC does not specify if you use negative or positive as the grounded conductor.
One of the leading module manufacturers requires positive grounding for their modules.
Jaref do not feel bad,you just fell into a trap into thinking for what ever reason the negative conductor is grounded. You can choose to ground the positive, negative, and none of them. This is how we keep auto mechanics and DIY out of our club.You're right, I was reading too much into it.
Section 690.5(A), only the current-carrying ungrounded conductor should be switched. It doesn't specify which one, only that only the ungrounded one is the switched one.
