- Chapel Hill, NC
- Retired Electrical Contractor
The other day I got a call from my brother in Texas who just had 3 Minkaire fans installed. Interesting string of events happened. Firstly I will say that candelabra based CFL light bulbs were used in the light kit.
The wall switch is one of those electonic switches that has a glide switch on the bottom which turns off all controls.
As we all know there always seems to be some leakage of current that is present on the load side of a dimmer. Why????
This is what happened. When the switch is turned off with the glide switch no problems are present, however if you just turn the light (dimmer) switch off the cfl flicker just a bit and can only be detected at night when it is dark.
There are 3 or 4 bulbs on the fixture and if one bulb is changed to an incandescent the flickering stops.
So my question is threefold:
Why is there a leakage?? when the dimmer is off?
Why is there flickering on the CFL?
Why does an incandescent stop the flickering?
