Hello,
I have a question regarding conductors in parallel, specifically taps to these conductors. The following is an excerpt from the 2005 NEC Handbook:
310.4 Conductors in Parallel
Conductors connected in parallel are considered a single conductor with a total cross-sectional area of all conductors in parallel. Therefore, if individual conductors are tapped from conductors in parallel, the tap connection must include all the conductors in parallel for that particular phase. Tapping into only one of the parallel conductors results in unbalanced distribution of tap load current between parallel conductors. This unbalance results in one of the conductors carrying more than its share of the load, which can cause overheating and conductor insulation failure.
So my question is this... Since this is just the "handbook" notes and not the actual code, what part of the codes tells us directly that we have to tap all conductors of the parallel conductor set? I've searched and searched and this is the best I can come up with but I'm not sure it'll stick because its not in the code, its in the handbook.
Thanks
Thanks
