Using 3/4'' rigid the other day, i was bending a small offset. 1" rise on greenlee hydraulic bender, with a total length of 5 1/2".
As u can imagine, w/ a radius of 9" this was a pain, but i did finagle my offset into the dimensions i needed.
The problem occurred when i tried to thread the piece. I left plenty of excess conduit on both ends. Measured the distance between the bends and had plenty of straight run to thread.
The problem occurred when i proceeded to use the pony, because the take up on the end is a about an 1 1/2" before the threading actually starts. The pony will actually catch on the bend before all the straight run is threaded.
After starting the threading on both ends i had high hopes the teeth were reversible to compensate for this.........they were not.
Do they make die's especially for these kind of situations, or is this just a wasted cause?
Thanks in advance for any responses.
