My helper drilled one 7/8" and one 2-1/2" hole 55 inches from supporting wall in a basement floor joist wich is a 2x10 is this ok?
Example to calculate safe areas
Measure the clear span between supports and the joist height.
E.g. 3.0 m (10’0”) and 150mm (6”).
Figures in bold type are constants.
Safe area for drilling lies between ....
0.25 x 3.0 (10’0”) = 750mm (30”) and
0.40 x 3.0 (10’0”) = 1200mm (48”)
The maximum diameter of hole is ....
0.25 x 150mm (6”) = 38mm (11/2”)
So safe areas to drill are from 750 to 1200mm from either end and up to 38mm diameter.
See the following guide...My helper drilled a 7/8 and a 21/2 inch hole in a 2x10 floor joist in a basement 55 inches from a supporting wall. Is this ok or what to do?
I like that guide better than the one I posted. I thought 1/4 was not correct but I just now realized that was from a UK site. :grin::roll:See the following guide...
http://arch.umd.edu/Tech/Structural...Wood_Products/Notching_&_Boring_Guide_A11.pdf
International Residential building code R502.8.1 Sawn lumber
2" minimum from top or bottom. D/3 max.
The diameter of holes bored or cut in to members shall not exceed one-third the depth of the member. Holes shall not be closer then 2" to the top or bottom of the member, or to any other hole located in the member.
We really ought to forward this info to the plumbers....
We really ought to forward this info to the plumbers.... I see some things that are not mentionable getting done.:roll:
When they cut out large holes they gusset with plywood as I described earlier. Apparently you can make a larger hole when you gusset with plywood on both sides.
