arits74
 - dixie arkansas
 - working owner electrician
5000 sf house totally finished, no problems  except 2 ceiling fans with the wall remotes that mount in your switch box on the wall,fans are on 2 seperate circuits in 2 tottaly different areas of the house,the afci breakers that runs these fans will not hold if the ground wire is hooked up to the fans,breaker stays on until fan control is turned on then breaker trips automatically,you can unhook the ground to the fan at the ceiling box and problem goes away.what are you suppose to do in a situation like this?
