George O'Brien
An industrial plant has new equipment going in. Power to it It will be supplied from a 4160VAC-480VAC Delta to Wye transformer. The neutral terminal on the secondary windings of the transformer will be tied to the plant ground grid to provide a zero reference and keep the system voltages from "floating". There will be a grounding conductor run from the transformer to the Switchboard even though both the transformer and Switchboard are tied to the plant ground grid.
But there are no 277VAC loads on the equipment. All motors etc. are 3phase 480VAC, and only three current carrying conductors are required to operate the equipment. The Switchboard has accomodations for grounding but does not have a neutral bus. My question is: Does NEC250.24(c) apply? That is, must a 4th current carrying conductor be run as the grounded conductor? if it must be run, what purpose does it serve? and where should it be terminated in the switchboard?
