Blacksmith Cycles
New member
I know this may be slightly off topic for you guys, but it does have to do the basic concept of Ohm's law so I hope you can help me out. I asked someone I know who is a licensed electrician and he referred me to this site.
In a 12VDC circuit with a battery as the power source, a resistor connected in series will eventually drain the battery. Common sense tells me that increasing the resistance will drain the battery faster. In other words a 6 ohm resistor will drain the battery faster than a 3 ohm resistor.
Here's my question...if I use Ohm's law (current = voltage/resistance) then:
12 volts / 3 ohms = 4 amps
12 volts / 6 ohms = 2 amps
Wouldn't a current flow of 4 amps drain the battery faster than a current flow of 2 amps? If so then will increasing the load (resistance) actually drain the battery slower?
Which way of considering this is correct and why?
I know ther is a basic key concept here that i am missing and will probably say "Duh!" when it is pointed out for me.
Thanks in advance for any help!!
