Curious about house wiring
qmavam
While contemplating having a transfer switch installed at my home,
I was looking at the outdoor power meter setup.
Underground utilities go into the meter box, the meter box
is connected to a circuit breaker box. The CB box has
1-100 amp breaker, 2- 60 amp breakers and 1-40 amp breaker.
The 100 amp goes inside to the main breaker box,
the 2-60 amp breakers go to the electric heater and
the 40 amp breaker goes to a conduit that goes underground,
I think to the air conditioner compressor.
My question, is it normal to have an external CB box like this,
or could this have been an add on? The house was built in 1973,
I wonder if it didn't originally have air conditioning.
Thanks, Mike
Thanks, Mike
Perfectly normal, and an advantage because the AC and well pump don't have to come inside
Mike, a quick clue as to whether the outside panel was an upgrade would be whether the inside panel has a main breaker. If it does, the outside panel was likely added.
Ah, no main breaker inside.
The CB box outside has about 50 chameleon skeletons inside.
I guess they get in and can't find their way out.
Thanks, Mike
Thanks, Mike
Maybe they just go there to die, like an elephant graveyard.
"I meant what I said, and I said what I meant.
"An elephant's faithful, one hundred percent!"
