Commerical lighting is considered continuous and subject to a 125% multiplier. It's obscure. Some snippet in a section that continous loads are subject to 125%. I think I'll crunch these numbers for fun today and see what I get.
Did you see, though, that the example would take 125% of the larger of either lighting load? I maintain that it is not Code, but still . . .This is true, but I don't think it plays a direct part in Art 220 when using Table 220.12.
Look at the example mentioned (D-3 pg 765 in '08) and you will see they compared the actual load (8500 watts) to the Table 220.12 calculated load (without the 125%) and selected the largest.
(T 220.12 is a "not less than number which in the OPs situation, is a lot larger than his actual load x 1.25)
... a big refrigerator the holds flowers.
runs all the time to keep flowers fresh...
One 240v 35amp AC omitted rarely used...
I was looking around and ran it to this written by the man himself-)
http://ecmweb.com/mag/electric_commercial_load_calculations/
... Assume the general lighting load for commercial occupancies other than guestrooms of motels, hotels, hospitals, and storage warehouses is continuous. Calculate it at 125% of the general lighting load listed in Table 220.3(A)...
The problem is that the NEC does not tell us in Article 220 to calculate it that way, Art. 220 does not refer to Art. 210, and I know of no rule in Article 240 that would do it either.
