A/A Fuel GTX
- WI & AZ
- Electrician
Ok, I have a dwelling that has meter and a 200A, 8 space feed through load center on the outside. From the load center, a 100A main power feeder ( # 4's ) is going to a panel on the inside of the dwelling. All is well in complying with 310.15(B)(6). Now, the customer wants to add another sub panel from the exterior loadcenter to feed some loads in the attached garage. Will the additional subpanel put the original main power panel in violation as far as wire size for the feeder even though the feeders for the new panel be sized from 310.16?
