HID Bulbs
firelient
Staunton,VA
Got a kinda dumb question here. The plant where I work Has both 480volt and 277V 400w hid mh lights they bought some off brand that has 120v wroth in the sleve they came in. I never really thought about it but can they be used in the lights we have if not why Thanks
HotConductor
Philadelphia
The lamps operate through a ballast, therefore line voltage doesn't come into play with the lamp. Just don't mix probe start mh lamps(400w) & pulse start mh lamps(400w).
AdrianWint
Midlands, UK
It may not be so dumb......
Here in the UK we have two kinds of high power (2kW) Metal Halide HID lamps, those designed to run from a 415V supply & those from a 240V supply. This is clearly stamped on the glass.
They both use different ballasts (obviously) and are not interchangeable. I guess that the manufacturer (Philips) has decided to use the higher voltage to lower the lamp current for the same power.
Confused the hell out me until I found the datasheet!
Adrian
