hockeyoligist2
- close to greenville sc
I have had five UPS, less than a year old, die in the last two weeks. Two separate motor control buildings. The AC's in both buildings were down for two months due to sewer gas causing leaks in the coils.
The temps have been above normal for May/June here, mid to upper 90's. Inside the metal MCC buildings the temps were 100 + degrees, the thermometer in the buildings max out at 99 degrees, so I'm not sure of actual temps.
Could the heat have caused the failures?
