- Connecticut
- Engineer
So I'm supposed to comment on your posts while you ignore the better part of mine... :roll:
So I'll take that as a No, P = H * D wouldn't give the pressure at the base of the cylinder in my example.:grin:
Close enough? Well taken that the all time percentage of objects weighed in places much, much closer to Earth's mean radius versus atop Mt. Everest, I'd guess the ratio to be astronomical.
So if the result would be close enough "most of the time" you'd just ignore the other times? I wouldn't
So do you also account for g-force deviation due to lattitude and the angle of g-force?
Yes, of course. Acceleration is a vector. It has not only magnitude but direction.
In a weighing of product, do you continually compensate for air bouyancy?
I don't have much call for weighing of product (I've never tried to weigh an electron
You do know the federal trade definition of a pound weight is within a vacuum, right?
I had no idea, and couldn't find any such definition on FTC.gov. Maybe its true, but it just goes to show if the FTC is that precise about the weight of a pound, then "close enough" probably isn't good enough for them.
When is the last time you checked the gravitational force at your location?
Never have. How about you?
