Air Compressor for Pneumatic Tools
Jeff80
I have a single phase air compressor with name plate rating of:7.5HP, 230volts, 31.4amps, 37 sf amps, and service factor of 1.15.
I am installing this to single phase 208volts. I dont do many motor calcs and I am a bit confused. I need help with wire size, breaker size, and heaters.
I think this is 55amp wire, 60 amp breaker.
before I would begin to guess with the information provided, I would need to know what is the overall distance from the source to the compressor. Voltage drop can be a major factor with a single phase motor that big.
your guesses seem to be in the right neighborhood (assuming distance is less than 75 feet or so), but I think I would use a 70A OCP at the source (I think an 80A is the max allowed by code in this case with the same assumption).
Mods --- Is it OK to post a link to a Manufacturer's web site to get this person a useful motor calculator??
Here is a link to an electrical formula page you might find useful:
http://www.electrician2.com/calculators/elcal.html
when using the motor calculation be sure to scroll to the bottom and complete the voltage drop section since, as poboy relates, it can have a significant impact.
In your situation, I would be concerned about the 208 v source. Compressors are often designed so close on HP that you very well may find the 230 volt motor is not going to perform on the 208 system.
For the reason Augie47 states is why I have wound up going back to "FIX" compressors like that by adding in a buck/boost transformer.
They MIGHT work for a little while, but the motors soon burn up and the saddest part is that many times a motor replacement on those single phase compressors costs almost as much as new compressor, often times MORE when you add in the cost of the buck / boost. Customers do not like to hear news like that at all.
