has anyone ever put heat trace on an outside gas line, could not believe it when I saw it. Code vio #
Perhaps 110.3(B) should be utilized to assure that the heat trace is actually listed for the purpose.
I guess a better question would be why would you need heat trace on a gas line to a store located in a large city?
Well if it's propane I could see an issue. Propane can turn to liquid and freeze in the line especially near the regulator.
I still think its water in the line. I've only seen it a few times. Here it doesn't get cold enough to freeze in the lines but in colder climates it could.
Yes I have seen it I can't think of why you would do it in a convenience store. When we build Gas Turbines or even some Natural Gas Engines they are temperature and pressure requirements of the incoming gas. if your supply can't always meet these requirements we provide aux equipment to meet them. we have talked about using electric gas heaters and have in the past used natural gas gas heaters.
I'm thinking 'locating wire'.
It is not normal but does happen. A break in the line caused one instance. Water got in and the gas company didn't get it all out. Water filled gas valves all over the neighborhood. They did step up quickly and pay for repairs. Another time the gas was to "wet" (not dehydrated enough) and water condensates in the lines.
