Micah Gastineau
New member
I know someone who is using an equip. grounding conductor as a grounding electrode conductor as well. I dont like it. Grounding is very important. He has a 2,2,2,4 type M.C. feeding a panel and has routed the grounding conductor from within the M.C. cable through the j.box from where it is tapped to structural steel. Is this issue directly discussed in the N.E.C. The M.C. is a temporary power supply to a new panel that was installed when a single structure was split for two new tenants. Upon new utility service being energized his plan is to cap off the current carrying conductors of the M.C. at both ends but leave the equip grounding conductor that is within this M.C. as a grounding electrode conductor. Can a grounding electrode conductor even have other unused conductors within the same cable or raceway? Besides being cheap and sloppy is this dangerous, is this a viloation?
