quinn77
- Lake Jackson, TX USA
ok...dumb question.
customer wants to keep existing 3 ph 240 volt 4wire overhead panel feeders to save money. I need to replace pole mounted meter loop and 100 amp fused disco. The feeders are 3 conductor #2 with messenger, however the service at pole is first point, therefore must keep grounded and grounding conductors seperate to load. Nobody makes a 4 conductor with messenger. Is there an exception in NEC that allows me to ground neutral conductor at meter loop and load. Load consists of 2 motor control panels and 1 lighting panel. I couldnt find in NEC.
thanx
Quinn
thanx
Quinn
