disconnects to fuse or not.
myrshub
central CA
When do you have to fuse a disconnect for an AC unit?
I understand if you have breaker that is too large amps wise you will have to install a disconnect with the appropriate sized fuses.
According to what I have read, I think I have to install a fused disconnect whenever the AC unit nameplate mentions a max. fuse size, even if it shows a max fuse and breaker size. :-?
If the unit says fuse or breaker you can use just the breaker. A fuse is not required.
