What happens if you have 2 different sized voltaeg sources in parallel with a load.  What voltage would the load see?  For instance if i had a 5V and a 10V in parallel connected to a load in parallel what voltage would the load see?
I know there would be a circulating current between the two sources depending on the impedances of the sources?
Would you have to do a mesh analysis between the two circuit loops to determine the current and voltage output to the load?
