Whatever the manufacture specs, is what I would go with otherwise you may end up compromising the inegrity of the lugs and buss bar.hello.
tinned copper lugs to tinned copper bus bars... what is the preferred anti-oxidant for both indoors and outdoors? and why... thanks.
The two products I mentioned are listed for copper only. The gray penatrox (that I don't use) is for aluminum, and perhaps copper. The copper product is far better for copper. we use on high amperage 12 v connections on emergency vechicles and the overheating just goes away.
There is one listed product by T&B called Kopper Shield, Burndys version is Penetrox E. Its a copper anti-sieze. I have used for years, its an excellent product. I use it on threads, connectors and conductors.
Tom,
Do you have a preference between the two? There's quite a difference in pricing!
Not I.I have some copper coat gasket sealer left over from auto work.. Would you use that in a pinch??
Never heard of that stuff so I Googled it and found this page: http://www.sanchem.com/. There are several versions of it and the electrical version seems to be No-OX-ID A Special.NO-OX-ID is what we use most often for similar applications.
