TxEngr
- North Florida
Petersonra ? I based my ?guestimate? on the information provided. For a 200 Amp, 480V panel, I would expect the rating to require at least a HRC2 and possibly HRC 3 or 4 depending on the age of the equipment feeding it. Removing the cover, I personally would wear HC4. One small slip up and the panel rotates into live bus. About the only exception I will make is if the door is properly hinged to control it and I know the arrangement of the contents of the cabinet to be clear of the area. Even then, we wear the correct PPE when opening the door. At my facility, we generally don?t remove covers from panels on energized equipment anymore, even for infrared work. We have started a program of adding infrared viewing windows to the gear for that purpose. Much safer since some of our equipment is old and is HC4. And we find the windows just as effective if placed properly.
