Are there any occasions that would allow rigid metal conduit to be buried 6 inches under ground on a residential job? Other than the notes at the bottom of Table 300.5
the trench only has to be 6 inches deep
How do you keep water out of any conduit? For that matter - how do you let it out????How do you keep water out of rigid?
How do you keep water out of any conduit? For that matter - how do you let it out????![]()
I don't have a pipe threader and with all the bending and threading involved . . .
With PVC you hope that you can seal the pipe with glue. But doesn't rigid use threaded rigid couplings? Just seems like the water can fill the pipe easily.
I don't know, I almost NEVER use rigid.
Not sure of the code implications - but with some pipe dope - you could make it gas tight....With PVC you hope that you can seal the pipe with glue. But doesn't rigid use threaded rigid couplings? Just seems like the water can fill the pipe easily.
I would doubt that pipe dope would give you that tight of a seal. I think you would need to switch the conduit couplings with plumbing pipe couplings to do that.Not sure of the code implications - but with some pipe dope - you could make it gas tight....
I've seen a detail showing the conduit with holes drilled in the bottom at a gravel sump, with conduits sloped down to that point. I can't imagine that maintains the listing requirements, but it is an interesting approach when you don't have a manhole to drain to.
Even if it's genuinely water-tight, undereground conduit will still get water inside it.Not sure of the code implications - but with some pipe dope - you could make it gas tight....
