jph320
- Cinnaminson nj
- Electrician
Can I convert a 200amp service into 3 seperate 100 amp servces by installing a 3 gang meter socket?
I looked at 230.2. The service is for a triplex. A 3 story house that is converted into 3 apt. The 3 panel boxes are on the other side of the wall from the meters. So is it possible to add a 3 gang socket from 200 amp drop to feed 3 100amp panels
I'd say if the load calculations for all three come in less than 200, then you could leave it.
Around here it would be allowed but, you may need a "house meter" if the apartments share a commkon hallway or a heating system etc.Can I convert a 200amp service into 3 seperate 100 amp servces by installing a 3 gang meter socket?
the place was gutted from a fire and zoned to be a 3 apy building when h new contruction is being done. The apt are all 1 bed, 1 living room, 1 bath and 1 kitchen(gas range). So the biggest load are gonna be the central air units. Each apt will have their own. I gues my next questions is just one ground rod? And do I just daisy chain it from panel to panel from the ground rod?
