Hendrix
- New England
Is there a code section that addresses ground rods at each light ?
Thanks, the exception is the keyYes, check out 250.32(A) and the accompanying exception.
Chris
Thanks, the exception is the key![]()
Is the pole a structure ?
Gotta be the single lamest excuse for a definition in the entire set! "That which is built or constructed." I built a kite in my youth. I once constructed an argument in favor of legalizing tap water. Sheesh! :roll:Check out the definition of structure in Article 100.
It is my understanding that the definition closely matches the building codes definition of structure.
Ergo, this forum is a structure.
So is my kids Teddy bear but it is unlikely that any NEC section applies to either.![]()
Are you saying that your kids Teddy bear is not grounded? Oh the humanity.
Chris
But it's AFCI and GCFI protected, as well as on a TVSS.![]()
