Is there a square footage calculation for rough estimates on one and two family homes?
A better method is to calculate based on the number of bedrooms ,baths,and living areas.i have a flate rate for a bathroom so if you have three bathrooms it is 3 x the rate.I do the same for bedrooms and kitchen and living room and laundry/utility. Then I add the service 100,200,400. Then heat/AC and HW. So a three bedroom two bath with 200A service central heat/Ac and HWH would just be a matter of adding the individual rates.
That may work fine if all the bathrooms and bedrooms were the same, I would not want to use that on some of the monster homes, or custom homes, tract homes, are usually a good place to use a flat rate schedule.
NO NO NO.
the answer will always be NO.
Most guys have a unit value for each task say 15 amp duplex receptacle, 3 way switch, 5" recessed lights. Add up each one of these tasks then multiply times the amount of your assigned value then add everything up.
Only then can you divide your price by the sq ft of the house and then you have your price per sq ft.
Square footage method for electrical doesn't work - GC's and GC estimators like to try to use this method but in reality it is based on past historical data and every house is different (unless you are doing tract housing where every house is the same)
you can have a 2000 sq ft house with 30 recessed lights, under cabinet lights, dimmers everywhere, extra 3way switches, cable, cat5, stereo, central AC, multiple heat zones, many outside lights, extra lights and rceptacles in the basement, decora devices, etc, etc -
You can have the sme size house with code minimum - which could have none of the above - with a rough sq ft guess - you would be way off on the first house described.
Remember the 70s.I worked for a guy in the late 70s building kit houses the only difference was the style of colums for the front porch and door.
Why wouldn't you just look at the plans and come up with a price![]()
Bar napkins and envelope backs generally don't have E sheets.![]()
if you have more then two drinks they might
