I have a floating dock that is attached to a fiberglass bulkhead via a hinged gangway. The dock and gangway is made of aluminum and decked with trex (a plastic composite decking). I am feeding a 200KVA 480:120/240V 1-PH substation with a parallel 3/0 feed (upsized to 4/0 for voltage drop. Does 250.102C "equipment bonding jumper on the supply side of the service", provide for adequate grounding requirements for the substation feed?
