Buck Parrish
- NC & IN
Will a double pole switch work as a 4 way switch in between two three ways? This is for lighting, of course...
Go get a 4 way and ohm it out and see first hand. DP switch have on/off written on them so obviously it will disconnect any current flowing when the switch is "off". There is no "off" position on a 4 way.
That's the reason I'm asking. I thought I had a 4 way but it is opening both travlers at once.
Nice drawing, however, there's a jumper missing from the outer travellers.
So both travlers are opened at one time. I thought a 4 way switch opened one travler and closed the other and vice versa...
And a double pole opens both simeltaneously.
I don't think so, sketch a 3-way on each side,hot to one 3-way and switch leg to other 3-way,then of course the light and neutral connected to the light.
dick
I agree with greeny. One of the poles on the bottom 3-way is not connected to anything.
Thats right and it doesn't need to be.......that contact is not used
dick
If you look at it this way,,,,,,,,,,, A 4-way is equivalent electrically to two 3-ways in one package and is a DPDT,with internal jumpering that is factory installed.
I started to write a explanation of metering but got all out of sync with myself so how about a picture.
