Hope this picture got attached was PITA
This is a large fountain job at a college with 18 water jets with LV 50 watt MR 16 lamps , lighting fixtures are with in the jet housing.
The controller supplies power an control wiring to 2 in ground vaults.
This Variable speed drive controller sent from the factory , check out L1 L2 L3 to the left of the picture , conductor put in behind a washer an nut , I removed nut an washer on L3 so you could see how it was done , anyhow we had to put in mechanical lugs on L1 L2 L3 - U V W terminals.
