stew
- federal way,washington
anyone know where i can sell a large batch of used fre breakers or is ther any market for them. ?
Go to ebay.... there are thousands of FPE breakers for sale.anyone know where i can sell a large batch of used fre breakers or is ther any market for them. ?
Unfortunately, when a breaker fails to open, you usually find that out the hard way.. . . there are millions out therer that5 havent failed as well
i highley doubt that i could be held resposible for someone elses failing piece of equipment. obviously they are failure prone but there are millions out therer that5 havent failed as well
I have several local breaker shops that will buy them.
I still have not seen any real evidence that these breakers are as bad as almost everyone says. I don't consider home inspection websites credible. Most of the failures that they attribute to the breaker such as loose connections in the circuit will not trip any breaker. The local breaker shop test all used breakers before sale and I have asked them many times over the years how often FPE Stab-Lok's fail. Of the thousands tested the answer is very few. They state the failure rate is equal if not less than all often brand breakers. I do realize that there was a short period of time that there were some questionable internal components used but that only effects a very small quantity of the breakers in service. Square D and Siemens have defective and recalled breakers still in service. FPE Stab-Lok's were never recalled.
Stevenje, the 40C is the ambient temperature rating. If you look at any current breakers it will have the same rating.
Sadly Jim some people are more into making a quick buck than caring about other's safety. The CPSC has had tests done on FPE breakers and they did have a statistically significant failure rate. Just because someone has seen FPE panels that haven't failed (yet) doesn't mean they are safe.
Remember too how they "fixed" the large frame breaker issue with a lousy warning label. THREAD HERE![]()
I cannot answer as to why they were not recalled, but can surmise that in that era the resources to make such a sweeping recall weren't in place. Strictly a guess on my part.
Candidly, to put these breakers up for sale on eBay is not only irresponsible, but the time and effort to list them vs. the costs and what you'll get for them makes it a huge waste of time and money.
If someone feels the need to get any money out of them, then the ONLY responsible thing to do is sell them to a certified circuit breaker rebuilder and let them test and recondition them as necessary.
