Electric-Light
v = 200v rms
i = 5A rms
no further information given
i = 5A rms
v = 200v rms
i = 5A rms
100801-0738 EST
This appears to be a trick question based on the strange wording of the question, and that the quick obvious answer is the first in the answer list. Based on the possibility of a trick question the third answer is probably a better answer.
The question could be what is the approximate power input at 60 Hz, or the visible spectrum power output.
Then it might be what is the power input at a frequency of 1000 megacycles/sec. At 30 megacycles/sec the power input is probably fairly close to 1 KW. But not too close a 1 gHz. Certainly the inductance of the bulb becomes significant at high frequencies. But incandescent bulbs have been used as a dummy loads for RF transmitters to estimate power output, and other purposes, even into the 100 megaHz range.
100801-1024 EST
.....Also if you operate at a sufficiently low frequency so that the bulb resistance is non-linear thru the cycle, then RMS volts * RMS current does not necessarily equal input power.
it stated RMS, doesn't that preclude any issues with frequency ?
Agreed. 1kw. Now, let's hear from the OP.At a basic ohms law level Dennis answered the question in the second post, and with no more information given, it is not a trick question as it is asked.
Overthinking??? In this forum??? Never. :roll:With that said, feel free to continue with the over thinking discussion. :grin:
It is a sickness. It really is. :grin:With that said, feel free to continue with the over thinking discussion. :grin:
...... If it is a pure sine wave, then we can use Vrms x Irms = P. If it is not a pure sine wave, then all bets are off. So since we were not told the nature of the power source, that is a key piece of information that is missing. Therefore, the correct answer is “C.”
